Is there a way to "reset" the gopro hero3? there are some files on the cameras internal memory that im not sure should be thee
We've found the best way is to remove the SD card and the batteries for at least 30 seconds and then reinstall both and turn the camera on. Remember, that in addition to the data saved on the SD card, by plugging your camera into your PC with the USB cable you will be able to find any images or video stored on the camera's built in memory.
We've put together a tip sheet for the GoPro Hero 5 cameras but much of the information will help you get the most out of your Hero 3. It is important that you do not attempt to update a Hero 3 using the available GoPro firmware update as it is ONLY for wide angle Hero 5 cameras.
If we can answer any other GoPro support questions feel free to visit us at IcePlanter.com or contact GoPro directly.
Hallo
bij mijn gopro als ik hem aan zet dan gaat die meteen filmen en **** hem niet stoppen met filmen hij blijft maar filmen en **** hem alleen dus uitzetten hoe zal ik dat moeten doen?
gr thijs
SOURCE: Internal Memory full; No memory card in; Will not take pictures;
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure: 1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory. 2. Insert the new card and do the format thing again to prepare the new card. Happy photography!
