Unable to install correctly - hd tv ok - dvd wont install
Phillips vdvhd 5520H recorder - followed instruction in manual - unable to get setup menu to show on TV to install - TV showing all digital channels - but dvd ????????????? help
yes the tv is new hd and coonnected cables as shown in manual
RF antenna cable(connect bewtween recorder & TV) audio/video cables - tuner interlink cable - scart adaptor but not need as not connecting to foxtel cableyes the tv is new hd and coonnected cables as shown in manual
AnonymousMar 30, 2014
the dvd will not show a picture Menu shows smart navi message?the dvd will not show a picture Menu shows smart navi message?
You can't post conmments that contain an email address.
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
You can download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
DVD's
are standard definition video sources. Number of lines output is 576
lines, whereas your HD TV set has 720 or 1080 lines. This difference
may result in a poorer image. However some DVD players are able to
“upscale” picture to obtain a very good picture. Check if your DVD
player has the following connectors: YUV, DVI or HDMI. For more
information, refer to the instruction manual of your DVD player.
Some HDMI or DVI featured
DVD players also have an internal processor that can upscale pictures
from a DVD to 720 or 1080 lines to provide an excellent picture from a
standard definition disc to your HD TV set. Those settings are
available from the setup menu of your DVD player. Please refer to the
If
your DVD player does not have those connectors and only has a SCART
connector, or S-VIDEO, or composite, there is not much to do to improve
the picture quality. Just make sure that you are not using the cheapest
cables and that the picture settings of your TV set are correctly
adjusted.
Some high end TV
sets have a picture improvement engine that can soften a noisy image.
Make sure that it is activated from the setup menu of your TV set.
Please refer to the instruction manual of your TV set.
If people and objects have weird white outlines around them. This may
suggest that your TV sharpness is set too high. Make the correct
sharpness adjustments from the setup menu of your TV set.
Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
