If the watch back has about 10 groves on it take it to a watch repairer.NO groves then a sharp knife like a small Pearing knife find the grove between watch and cover put knife in and gently prize open.
There is two methods of removing the back of this style of watch. Look closely at the back of the watch. If it is completely smooth there will be a notch or groove where you can gently, but firmly, lever the back cover off. Use a small screwdriver or a thin flat edged tool, NOT a knife! Refitting is a firm, constant pressure over the whole of the back cover.
If there are regular notches, grooves or holes or around the edge of the cover it is a 'screw off' cover. You may need a specialist tool to remove these back plates.
Depending on how much the watch is worth and the cost of the battery it is probably just as easy to get a watch repair shop to do it for you.
I have seen other burberry watches and the back should pop out . 1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
To remove the battery from the back of an Oasis watch, you will need a small flathead screwdriver or a coin.
Locate the battery cover on the back of the watch. It is typically located at the 6 o'clock position.
Insert the screwdriver or coin into the notch on the battery cover.
Gently pry the battery cover off of the watch.
Remove the battery from the watch.
If you are replacing the battery, insert the new battery into the watch, making sure that it is oriented correctly.
Replace the battery cover by aligning it with the watch and pressing it into place.
If you are having trouble removing the battery cover or if the watch has a different type of back, you may need to refer to the manufacturer's instructions or consult a professional watch repair service. It is important to handle the watch carefully to avoid damaging it.
watches. Remove the back cover off the watchto reveal the battery. There are a very large range of batteries for watches. Remove the battery with non metallic tweezers or a sharp no metallic point. ...">watches. Remove the back cover off the watchto reveal the battery. There are a very large range of batteries for watches. Remove...
the cover doesnt appears on the back side of the watch it is engraved with the main body of the watch,take it to a sevice centre they have tools through which the back cover gets separted with the main body of the watch
mcdevito75 here, The serial number is the number off the movement itself. You"ll have to remove the back cover of the watch or have a watch repair shop remove the back cover and record this and all info on the watches movement. Any info on the back cover of any watch can help somewhat but you need the info off the movement itself for accurate info regarding any watch.
mcdevito75 here, Basically there are 3 ways to remove the watch back, If there are 4 screws holding the back onto the caseing you"ll need jewelers screwdrivers to reove the screws and cover, if there are square holes going around the edge of the back cover you"ll need a special tool called a case back remover tool available on ebay to un-screw the back cover, or the cover simply prys off. Look for a tiny tab on the back cover you may need a magnifier glass available at most Dollar stores or there may be a **** between the back cover and case of the watch to pry off the back cover, use a sharp knife and carefully twist the knife oncwe you find this tab or ****.
mcdevito75 here, Most Lorus watches use a press fit back cover on their watches, simply us e a knife with a sharp edge between the case and cover and with a slight twisting motion the cover should come off, Also Look for any slots in the cover that match a slot in the case, or a very slight extension or lip on the cover, this is where you"d place the knife and use a slight twisting motion to remove the cover. If there are screws on the back cover you"ll need to remove those screws to get the cover off. Your Local small watch repair shop can help out.
On some watches, the cover will pry off using a very small flat-bladed screwdriver or will have screws holding the cover on. On other brands the entire cover will unscrew. Examine the edge of the back cover. If there is one small depression along the edge of the cover then the cover will pry off. If there are screws present, the cover will lift off after the screws are removed. If the cover has a raised edge with flat edges opposite one another then the cover will unscrew.
Try removing the rubber washer or the black band on the cover then try snapping it back on. I removed the washer and placed it on the back of the watch before I placed the cover on and it just snapped back on.
