Unfortunately, there are no Free region hacks for this player. But for about 15 bucks, you can get a hack from here:
http://dvdexploder.com/dvdsales.htm
Hope that helps!
You could also try this:
Or you can try http://tinyurl.com/46sop8 for $9.95..Open The DVD Door
Press Language Button Once
Press Return 3 times
You will then see the region code on screen
Use your up and down arrows to select region 0
YOU ARE THEN REGION FREE
Welcome-
I'm sorry to tell you that if none of the other ideas that have been given to you wil work, then most likely the codes and procedures have not been released yet. I know thats not what you wanted to hear but I also searched the web and was only finding what everyone else has told you.
i'm sorry that fixya couldn't help you
happy holidays
Tom
I think its your philips dvd pdv-722.So i will like to inform you that our whole world is divided in six dvd region that 1 for US and 6 for china. so that one cannot buy cheap dvd from china and run it in US. SO to solve this there is one site which will provide you with sofware to unlock the region code.from dvdunlocker.com
The regions can be changed with the alrady mentioned settings in the remote.try to look for it.thank you
If you own a DVD player
from Durabrand, private product brand of Wal-Mart, you can use the
following hack to unlock the Durabrand DVD players’ region code so that
the DVD player can plays any DVD-video
discs regardless of the discs’ region code. In other word, the unlock
DVD player hack set the Durebrand DVD player to become multiregion, or
region free.
The above unlock DVD player region code trick should works on models
including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c,
Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players
from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player
model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970,
Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand
Dual-7BL, try the following unlock code instead.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
Note: To set back the DVD player to region 1 if you’re using above
unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit
in the key sequence is actually the digit to determine which region
code you’re going to set on the DVD player. You can set to other region
code by changing the last digit to 2, 3, 9 or other valid region code
number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
Note that if you select “Region 0′ which allows DVD players to plays
all DVD-Video discs from Regions 1-6, some DVDs which are incorporated
with “Regional Coding Enhancement” or RCE protection system will refuse
to play in such machine.
region free.
from Durabrand.
number.
hope this helps.........good luck!
Try these steps
Or
Or
Or
Try this one for your model.
Switch on
Open Tray
On the remote press the following in order - 9, 7, 3, 5
Hidden DVD Region menu appears. Select your required region.
Exit menu.
Good luck
regards
robotek
It appears that as yet, there is not a FREE  one about on the Net yet.The hack I gave you was for the same series of player "pdv7XX" , and it is worth trying ANY  hacks unlock codes for Lennox/Durabrand make of DVD. Sometimes the same electronics may be used.  Clumsy approach, but may well sort it out for you. Other than that, it may well be worth emailing Durabrand distributors in your area and request any information they may have pertinent to your model.Â
regards
robotek
Sir,
check this link
As per information available on internet. No region hack for this player till yet. Better to contact customer service or replace if u have warranty....
thanks
good luck
Heres the step to do that
from Durabrand.
using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960,
Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand
STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following
number.
Alright, just follow these steps and let me know if you have any problems or questions
Thanks for your help but I've tried this one an it desn't appear to work for this model.
Cheers
Trent
Thanks again for the extended response but I actually tried these before posting here andnonw work for this model.
Cheers
Trent
Still no joy, I've tried everything from this link so please only post if you know about the hack for this model
http://www.mydigitallife.info/2006/12/24...
still nothing..
Thanks for your help everyone.
Please only respond if you know it works with the model Duraband PDV-722 as all the previous responses DO NOT WORK!!
Thanks but it is made by Lenoxx don't think it is a Philips machine. I already checked the DVDunlocker listing and it isn't listed under Durabrand or Lenoxx.
