Problem : When using the labtop out of the docking station (mobile mode) with external mouse and putting it back into its docking station (office mode) the Keyboard and mouse both attached to the docking station will not be detected any more. Questions : 1) How to prevent this? 2) Is there a way to redetect the ext. keyboard once put back into the docking station? (->detect hardware ...?) Many thanks in advance.
SOURCE: Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking.
shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8.
advance boot up options will appear.
select safe mode with networking
try restoring your comp to a previous time when it was working.
if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
Hi Alex, in Win XP there is not such button "Add a device". Any advice how to find it?
It is its just trickier to find, it should come under a "Hardware and Sound" category. To be honest, if they work on the portable mode, reconnecting them whilst the pc is docked should fix it.
I already tried this out. Negative. The keyboard plugged into the docking station will not be detected again. Any other tipp ?
with the pc in portable mode, go to you list of devices, right click on the key and mouse icons and there should be an otion to "update driver software" you'll ned it to be connected to the internet to do this. failing that, remove the devices, delete the devices off your device list, and try installing them with the PC in its dock.
Faisal Ahmed , your solution proposal is NON-sense. For sure all virus infections were checked before posting.
