I got a TI-Nspire for Advanced Functions and Modeling, but the Sin, Cos, and Tan don't give me the right answers. I've tried changing the settings and it doesn't fix it.
But prior to you ought to find out some new things concerning Insta. Official Website computer by simply filling up some required information and your.
APK Authority is a site where you will find all the latest updates about Android applications and how to install them on your devices. here you would find the best Android apps that you can install on your devices and enjoy the great experience
See angle unit setting below
It is additionally an instantaneous messenger Web Snapchat Though this is simply a minor issue for a lot of individuals.
The trig functions depend on the angular mode. Make sure you have the proper one set.
SOURCE: I'm trying to do sin
It is very likely that when you change the angle unit, you are not saving the changes made.
After
you finish changing settings, use the TAB key repeatedly to move
cursor towards the OK button at the bottom. If you do not confirm
changes by clicking OK, they will be lost.
You can also make the changes the default ones by clicking the Make Default option.
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
mine either. I get 1 for cos(pi) but it should be -1. I do get -1 for cos(180). I've tried all the settings but cant figure it out
