DISPLAYING ERROR CODE D-08-224 AND RED LIGHT NO.4 AND ANOTHER RED LIGHT FLASHING
SOURCE: Toshiba e-studo120 H4 error code
This should do it.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
SOURCE: Flashing error code
SOURCE: ERROR CODE
could you please let me know the right code for activation of the copy machine ???
SOURCE: My copier displays a flashing
The H4 error is related to the Fuser Unit not reaching the correct operating temperature in the correct time. You can try clearing this error with the following:
Make sure that the machine is switched on and the error is displayed. Enter the Service Mode by pressing the following keys # * Clr *
Enter 14 and press Start. Then power off the machine, wait 30 seconds and then power back on. The error should have cleared. If not then you will need to call in a service engineer.
SOURCE: MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
