Remove screw on panal around handle that opens car. remove 2 screws underneath handle that pulls door closed. check around door panal edge for screws and if so remove them. Now remove panal by prying slightly around edges or panal as to pull the clips loose. Dont bother if some break,they can be easly replaced and dont cost much at all. I always use a still putty knife to help pry panal off. This insures you dont crack panal while pulling on it. Once thjis is dont you will have access to the switch...Simply replace it and place panal back on and HEY !! you did it..... hope this helps and if so Please leave rating on this post and good luck..
Door Panels
Fig. Fig. 1: Remove the cover from behind the inside door handle by gehow to remove ford taurus window switch - 0900c152802604e5.jpgto release the retaining tabs
REMOVAL & INSTALLATION
See Figures 1 through 8
This procedure applies to both the front and rear door panels.
Fig. Fig. 2: Remove the pull cup retaining screw cover and...
Fig. Fig. 3: ... remove the retaining screw from the cup and lift the cup straight up out of the door panel
how to remove ford taurus window switch - enlarge_icon.gifig. 4: Remove the two sail panel/how to remove ford taurus window switch - enlarge_tooltip.gifining screws and...
Fig. Fig. 5: ... remove the panel/grille from the door
how to remove ford taurus window switch - 0900c152802604e9.jpg/images/0900c152802604e8.jpg" alt="0900c152802604e8.jpg" class="h_mi" />
Fig. Fig. 6: The door panel is retained to the door by 11 retaining clips
Fig. Fig. 7: Carefully lift the door panel off of the door and...
Fig. Fig. 8: ... detach the electrical connectors from the switches and remove the panel from the vehicle
SOURCE: :Remove key switch on `91 Ford Taurus?
If you mean the switch that the key cylinder operates, it should be near the floor on the steering column. You just disconnect the harness and remove two screws.
You have to remove the cover around the steering wheel and push a pin to remove the key lock. There are videos on YouTube to do that.
