I have a Phillips GoGear Mix 4GB and after fully charging it, the next day it is completely dead. I know that it's not on over night. I hold the power button down until it says, "Bye", so it is off. The charge is supposed to last 25 hours, but it's not lasting at all. It's only two months old.
I had a frozen screen too just five minutes ago. I thought it was completely broken until I realised there was a reset button on the side of the mp3 ^^
Hope this helps
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Hope this helps
To reload drivers: WARNING: this process will erase all songs off the GoGear. Disconnect the GoGear from computer. Turn the GoGear off. Hold in the volume + button. Reconnect the GoGear while holding in the volume + button. Continue holding the volume + button. After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now). Good To Go (Gear)! -Tha Mp3 Doctor
Software can be found by going to: www.usasupport.philips.com Enter your model number On the next page, click on your exact model number without the "B" on the end On the next page, click on "software and drivers"
Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard). -Tha Mp3 Doctor
