I checked the sd card to see if it was locked, but it wasn't. i can still take pictures, but they come out of nothing but a black screen. i can access different settings and the menu, but like i said it's just a black screen. does this have anything to do with the lens? can i fix this?
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: Pentax Optio 555 LCD screen blank problem
The LCD can be turned off simply by pressing the display button when in picture taking mode. It has 5 different states, one of which is completely black. Try cycling the display button.
SOURCE: Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
SOURCE: Unlock Pentax Optio S5z
I had the same problem with the exact same camera (Pentax Optio S5Z) that happened the same way. I searched everywhere on the web and finally found this post that didn't have a solid solution. So I started experimenting with different button combinations and finally figured it out.
Hold the OK button while turning on the camera. The screen should indicate that it is in audio record mode. Now press the Menu button and use the navigation keys to find and execute the system reset option.
After turning it off and back on it should function normally.
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
SOURCE: card locked
The card has a lock on it which must have been disturbed, just take it out and slide it to unlock.
