I tried to run the device repair from the computer, and it's stuck on Restoring to Factory Settings. I tried everything but nothing works. The thing gets stuck at the ViBE splash screen. It does go into recovery and MTP does work. Any suggestions as to what do to? Or do I have a brick?
SOURCE: philips gogear mp3 stuck on gogear screen
try putting it into recovery mode by holding the volume up while plugging it into the pc this might at least get the pc to see it also try it with a diffrent cable
SOURCE: I connect my device(philips gogear Vibe 4g.)The
Hello :
1: Unplug your Mp3 player .
2: Restart system .
3: Plug the Mp3 player again .
If the system didn't recognize Mp3 player this time , then :
1: Go to [ my computer ] icon on desktop .
2 : Mouse right click .
3 : Scroll down to properties .
4 : On properties click [ Hardware] .
5 : Click [ device manager ] .
6 : On device manager check if all [ USB ports ] are properly installed and working fine .
7: If there are [ question marks or wrong marks ] on the ports then they don't work properly .
This is what you need to do , if they don't work properly ;
1 : Right click on the none working ports .
2 : Scroll down to properties .
3 : On general click [ reinstall the previous program ] .
My computer icon .
Device manager
USB mass storage device problem [ not working properly ] .
Here you should right click on the none working device then go to properties and then ,
Troubleshoot .
I hope this will help .
rate please !
SOURCE: Not able to play video in philips gogear pls suggets
Media players need the matching video format: for GoGear Vibe it is SMV.
To convert video from AVI to SigmaTel Motion Video, use the Media Converter Software from the manufacturer. For the videos you'd like to convert, be sure to update video codecs in Windows Media Player 10 or higher.
Vibe players have different display sizes, so you'll need the matching Converter for your player.
When you have the United States version SA5285/37 next site gives all support, including the Arcsoft video converter:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5285/37&slg=en&scy=US
note
There's and update for the Arcsoft converter, for downloading directly YouTube films:
click on EXTRAS at the top right hand corner of the Arcsoft main screen.
At the pull down menu click UPDATE AND PATCHES, Arcsoft will check
and let user download and install the updated Stream Ripper feature
( streaming videos need flv video codec )
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
You can find the recovery key on your player from the below table.
If you need any further help, please email us back so that we can continue to work on a solution.
