Dont have my manuel with codes for my universal remote. It is a quantum Fx rem-111, and I have a zenith tv and a hiteker dvd player
Check this link to download the user manual to your remote control.
SOURCE: I have a quantum fx
I have quantum fx rem 115 jumbo universal remote, I lost the manual. How can we program our durabrand tv
SOURCE: I HAVE A REMOTE CONTROL QUANTUM FX REM-100 AND I
The Lg tv codes are 0002,0606,0502,0102,0117,0814,0324,0435,0802,0307,0609,0217
Hold down tv until the light stays on then enter code light should go off try volume or something to see if it works
SOURCE: universal remote
You can find the remote control codes for difrent brands of
devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try
to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: lost codes
SOURCE: i have a quantum fx REM-100 remote control and i
I bought a Quantum Fx (REM-102) TV remote control for VIZIO TV but the remote control don't response I did intent some codes to control programming but don
