How do I unlock the security lock? I seem to have entered the wrong code enough times that it won't even let me try a different code.
I didn't even know this phone had a security lock, much less set a password!!
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
Use Menu 4-3-2-3 (Settings- Security settings-Access Codes - Change lock code) to change the lock code.
When the phone requires the lock code, it displays "Enter lock code:".
Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code. Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number)to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
Calling the unlocked phone number.
Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
When you enter wrong code for more than 5 times your mobile gets locked,so if you enter master code/unlock code also your mobile will not get unlock..... Solution :just switch off your mobile ,start it after 15 minutes and enter the unlock code i have given below i.e :5335036136 Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136 This will definitely break your mobile security code ...........enjoy ------------------------------------------- Please let me know your feed-back.
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: The default security code for Nokia is 12345 This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code
The default security code for Nokia is 12345 I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. Then I’ll give you the Master code to reset your Security code.
"Confucius he say: He who sits on tack is better off."
SIM Pin Code. This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. ---
To reset this Pin number you need the: Pin Unlock Code (PUK) If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
To reset this Security number you need the: Master Reset Code
For IMEI 356404010441953 this is the Master Code: 3520316615 to use it: You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
