Check the paper trays ensure guides are set correctly and check behind the draws no paper stuck behind, also remove any paper from draws which is considered storage paper.
The error means that the printer has determined that length of paper in source specified on second line of display is too short to print formatted data. If this error occurs again, press Go to clear message.Ensure paper size setting in paper menu is correct for paper size.
This error means that the media in tray XX doesn't meet the specified standard of the tray. The specified tray is loaded with media that is longer or shorter in the feed direction than the size configured for the tray. Please check the paper size in current tray or touch OK to change the tray.
To resolve this issue Touch OK to display tray size. Reconfigure the size in the tray so that it uses size of media required for the print job. If the message doesn't clear automatically from the control-panel display, turn the MFP off, and then turn the MFP on.
Restart the printer and repeat the above procedure if issue is not resolved.
CAUSE: This error
message indicates the paper present sensor flag in one of the trays
does not detect paper in the tray. This could be caused by one of the
following:
A broken sensor flag
The tray paper guides being set too close and restricting the paper from being pulled
The tray is not lifting
SOLUTION:
Follow the steps below to determine the cause of a false TRAY X EMPTY message.
Tray 2 empty
Verify there is paper in the tray.
Open the duplex unit access door just above Tray 2 on the front of the printer.
Check the black-paper present flag by looking in through the duplex access door.
Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
Remove the tray guides from the tray
and reseat them. Ensure the guides are seated correctly and are in the
correct slot for the size paper in the tray. Add paper to the tray and
try printing again.
Try another known good tray, if available.
The tray does not lift and the error is still present
Remove
the tray, remove the paper in the tray, and inspect the lifting plate
in the tray for damage. Ensure it will lift freely by hand.
Try another known good tray if available.
Tray 3 empty
Remove Tray 2.
Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
try printing again.
Remove
Tray 4 empty
Open Tray 4 and check for an extra
**** of paper stored on the left side of the tray. This can cause the
tray to stall while lifting and result in a tray empty message.
Defeat the interlock in the vertical
transfer unit (VTU). Open and close Tray 4 and watch the tray lift
through the VTU door on the lower-right side of the printer.
NOTE:
Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
Inspect the paper present sensor for damage.
Check for any broken plastic pieces in the tray that may be a broken sensor flag.
Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
C0204 - Tray 2 Elevator failure - The Lift-Up Sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.
1. Turn OFF the Main Power Switch. 2. Turn Main Power Switch
ON while pressing the Utility/Counter key. 3. Touch [Trouble
Reset]. 4. Check to make sure that [OK] is displayed and the
it has been reset. 5. After turning off the Main Power
Switch, turn it on again more than 10 seconds after and check if the machine
starts correctly.
Reset your Toners and
Imaging units for Minolta Bizhub and CF series. http://www.chipreset.eu
I have encountered this error before. Printers have a sensor on the trays to detect the level of the paper in the tray. First try fanning the paper that you have in there. At time when the printer try to feed a paper and it has a hard time picking the paper up, it may display the no paper error message. Fanning makes the sheets of paper separate from each other making the paper pickup and feed process easier for the printer. And if there are adjustable levers around the paper in the tray, make sure they are snug around it. This helps the printer identify the paper size that's in the tray.
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Hi, there must be an actuator of the output tray sensor.It is placed above paper tray, just in place when paper exit from machine.Try to clean sensor,or to place actuator in proper place-pull it down.Also,maybe is actuator broken.
ERROR CODE F3-12 ON SHARP MX 2300N
