Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: how to repair samsung Highlight cell phone screen
you might have to take it back to the phone company
SOURCE: can i unlock a highlight t749 with out my
Unfortunely you can't due to the secruity on the phone,but you can call Customer Care and they will ask you to type in some passwords and if they don't work, then you have to buy a new sim card from T-Mobile.They normally cost about 20 bucks from a T-Mobile store.You can also back-up your old information and put it on you new sim card.How this helped your problem!
SOURCE: i samsung highlight t749 security passcode reset
easiest way is to open up your dialer and type the following code: *2767*3855#
If you get the unlock password screen at boot up, try hitting the SOS in the bottom left, if it brings up the dial screen then type it in. It will reset the phone to factory settings and reset the password to 0000. You can then confirm this worked by going into menu/settings/reset settings/master reset. Then type in 0000 when prompted and again to verify. If your phone resets again then you know your password has been reset to factory default.
