Whirlpool Duet GHW9150P Front Load Washer Logo
Anonymous Posted on Dec 18, 2008
When Istrted to wash my cloths , the washer stop and post F-20
What is F-20 . please help . the cycle keeps stoping and not spinning
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Dec 19, 2008
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
28417
Points
47
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
When Istrted to wash my cloths , the washer stop a - drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316723
Points
2631
Remove bottom cover and ck/ clean pump
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Start matsui washing machine
Check the washer drain hose for clogs.
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
2answers
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Dc code appears only when clothes are in washer during spin cycle
If it’s an FAV6800A I think you may have a clutch malfunction with your machine. To verify if the clutch has malfunctioned we need to perform a quick check. Please visit this link and review my post of Solution #1 posted on Jan 30, 2009. Steps 1 & 2 should get you started and give us some troubleshooting direction. Please post back with your results or if you have any questions.
http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
Good Luck… Rich.
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
1helpful
3answers
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
1helpful
Need to get water out of washer SPIN CYCLE DOESN'T START PLEASE HELP
If this is a Whirlpool, Estate, Roper, or Kenmore model Top Loader, the problem is a lid switch malfunction. This is the most common symptom when the lid switch fails. The washer will either fill normally, then stop. Or, it will fill, agitate, then when it gets to the spin cycle, it will stop. If these match the symptoms you are experiencing, please post back and let me know. I can assist you and explain how to repair this problem. This is an inexpensive repair that anyone can accomplish with a little guidance. I have step-by-step instructions posted under the "Tips and Tricks" section of my profile.
Please provide as much information as possible when posting questions, as all washers are not alike and symptoms differ between models. This makes it much easier for us to provide you with the proper diagnosis. Let me know if you need my assistance.
PS You do not need to drain the wash tub to repalce a defective lid switch. The washer will drain on its own if the switch is replaced. In the interim, I can also give you advice on how to by-pass the lid switch as a temporary means of draining the washer.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
