Tried the codes listed for ILO that came with the universal remote, but no luck. Not sure what the problem is, or how to fix whatever it turns out to be. Message comes up each time I turn on TV: "Digital signal low"
Codes to check with ILO TV are: 0198 1070 1024 1023 . Keep in mind that.
If one code do not match with your TV, try an other code only after switch OFF the TV by its Main Power On/Off switch, and switch it back again.
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
SOURCE: I nedd the universal remote code for an Ilo tv
for Ilo TV are (042,051,053,155, 189,198). Use the codes under funai-it's the same company. It works on mine. CODE 189
