Question about Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP6000D prints white streaks thru the words
It doesn't print a solid readable word(s). there's white lines thru the job. the printed words are broken, not sold
  • bud katz Aug 14, 2012
    Thank you Douglas for taking the time to try to help me!. Tried all the nozzle checks, cleaning etc & changed the cartridges on ink that was low. Still printing out with the white horizontal lines.
    Novelist:
  • 153 Answers
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Posted on Aug 13, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Posted on Aug 25, 2008
Anonymous
SOURCE: Printhead problems Canon PIXMA MP780
that definitly sounds like it needs to be replace, have you tried using the printhead cleaning utility?
Posted on Dec 23, 2008
Melvictor Gopez
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Douw
Douw Coetzee
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
SOURCE: My printer Canon PIXMA iP6000D
Error 5200 is print head temperature rise,you need to change the print head.The part number is QY6-0050.If a have been useful please give me a vote :)
Posted on Mar 11, 2011
Printing streak
If the line is vertical on the print this is most likly not a print head issue. I would be more inclined to think there is a physical contaminant that might be "scoring" the print or scraping of the ink as the photo leaves the printer. Hold the print at an angle and shine a light on it to see if there is a difference to the surface of the print. Investigate the printer for obstructions and contamination. Pay particular attention to the feed mechanism.
Oct 03, 2012 | Canon Pixma iP6000D InkJet Photo Printer
My cannon ip6000D printer is saying its offline and wont print.. please help
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jun 01, 2011 | Canon PIXMA MX310 All-In-One Printer
My printer Canon PIXMA iP6000D stopped printing and ERROR 5200 appeared.
Mar 11, 2011 | Canon Pixma iP6000D InkJet Photo Printer
Ihave a canon pixma iP6000D want to mirror image
Download some free software, the "GIMP" (Graphic Image Manipulation Program) from http://www.GIMP.org and use it to "flip" your image.
May 30, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Dec 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma ip6000d
First you need to check that the printer has the same problem with a new cartridge, otherwise may be a cartridge problem. After this try doing a nozzle cleanup. You will find the option on printer properties in control panel, or opening canon software from start menu. If after this you still have the problem then you should open the printer and clean the waste ink well and printer head.
Feb 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Streaky print out from canon Pixma mp830 all in one
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
170 people viewed this question
Clive
Clive
old marine
old marine
Ekse
