Brother XR7700 Logo
MysticMint Posted on Aug 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Presser Feet for XR-7700
Does anyone know if the following presser feet fit the XR-7700? All say they work for Brother Machines with 7mm feed dogs, but when I look at the Brother site the XR-7700 is not listed as a compatible machine. TIA! SA-109 - 1/4 Inch Binding Foot SA-120 - Gathering Foot SA-126 - Narrow Hem Foot SA-150 - Pearls and Sequins Foot
sylviaivie
Level 3:
  • Brother Master 1,564 Answers
  • Posted on Sep 19, 2012
sylviaivie
Brother Master
Level 3:
Answers
1564
Questions
Helped
426400
Points
3583
Trust the Brother site and not the merchant.
5 Related Answers
Anonymous
  • 3422 Answers
  • Posted on Feb 22, 2008
SOURCE: Brother sewing machine # CS 8072 part
Got your presser foot part.
Part no.-(# 5011-3)
Cost -$10
Click HERE to buy
Goodluck..
Anonymous
  • Posted on Oct 18, 2008
SOURCE: brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Anonymous
  • 65 Answers
  • Posted on Jan 05, 2009
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Anonymous
  • 37 Answers
  • Posted on Apr 16, 2009
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Jan 20, 2011
SOURCE: My mother used my brother
for parts try sewingpartsonline.com
manual
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
yes,it's worth the money to replace the feet,, & buying a new or used sewing machine as a back up is good too
Presser foot to high?
Are you using the correct presser foot for your machine? Presser feet shanks come in different lengths. There are also a couple of presser feet (like darning or free-motion-quilting feet) that are shorter than standard because they are made to be used with the feed dogs dropped and the fabric can be manually manipulated. If it's the correct foot, then the machine probably needs to be adjusted.
https://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx?sort.ss_cat_sort=desc&index=1
1helpful
Fabric feeds crooked when sewing
Would suggest taking your machine for service. Could be the feed dogs need adjustment or realignment. Also, make sure you are using the correct presser foot for your machine. With all the new machines that have 7mm and 9mm presser feet (most older machines have 4mm or 5mm), using the incorrect width presser foot may cause the fabric to skew.
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
1helpful
I wish to purchase a binder foot, but don't know if I use the old or new style of feet! I have a 440QE which I bought about 10 years ago.
Your 440QE takes the new style Bernina feet (the ones with red writing on them.) Where it attaches to the presser foot bar, the front is flat and the back has a little square cut-out. Be sure you buy the narrow foot not the wider foot (& wider stitch) for the machines with a bigger foot print. (You'll be looking for 5mm wide, not the ones with the bigger foot print--7mm.) I do have a couple of 7mm feet for my 440QE and they do work but I read somewhere that they may be a little *hard *on* the 440, so I don't use them a lot. The 7mm presser foot is wider than the feed dogs on the 440QE.
General sewing Products BERNINA
http://www.sewingpartsonline.com/bernina-sewing-machine-presser-feet.aspx
Ugh, Fixya thinks I'm using bad language. Not!
1helpful
Compatibility of sewing machine feet
If the width of both machines' presser feet are the same, the only thing you need to worry about is the shank and the form of attachment the shank has to the machine.
According to this, the feet may be compatible:
Generic Presser Feet Accessories
You'll need to verify that the shanks are the same between both machines. Perhaps the Juki dealer can tell you if the feet are compatible.
However, if the presser feet are not compatible with both machines, you can purchase an snap-on adapter shank for the Juki and pick up a kit of snap-on presser feet (these are generic, not Juki made) and you will be set to go for very little outlay of finances. In addition, you could pick up a snap-on adapter for the Husqvarna and you would be able to use the snap-on feet on both machines (in case you don't have some feet for your existing machine).
32PCS Sewing Machine Foot Feet Presser For Brother Janome Yokoyama Juki UL
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
1helpful
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
Sewing machine is pushing the fabric through the presser foot unevenly
Your machine feed dog is ageing or need to be realigned or if you have a satin presser feet try to use this feet instead.
Brother XL-5130 machine...cannot get it to darn or embroidery work. I covered feed dogs with the plastic cover but cannot find a lever to put down the feet. With presser foot lever down (no feet and not...
You probably do not have lever to put the feed dogs down. That's why you have a cover. To free style embroider or darn you don't need a foot but the presser foot has to be down and as you run the machine, YOU will be doing the stitching by moving your fabric back and forth. This is usually done with a wooden embroidery hoop so that your fabric stays taught. I have done it on jeans without a hoop. Hope this helps.
5helpful
Feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
