Lochinvar controller lights up and thens soft lockout ingition failure
SOURCE: hayward h100id1 above ground pool heater has
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
SOURCE: pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
SOURCE: Pool heater will light then turns off
check gas pressure you should be getting about 10" water coloum
SOURCE: I'm thinking of buying a Lochinvar Energyrite
My boss once asked me if I could work on a Lochinvar. I told him I could pronounce it.
Chevy is a car and so is Mercedes Benz. Lochinvar is the same kind of German engineering. Quality product. Tough to find people qualified to work on one and pricey at that. Great heaters though. As far as the model I have only worked on the big ones.(commercial) I have found if you work on them one time they stay fixed.
SOURCE: Hoard pool heater IF Failure.
You did not list what model heater it is that your working with. Nobody will be able to answer this question. Please repost with the model number and wed love to help
