My reciever shuts off after i turn the volume up. When i turn it back on and lower the volume it plays, then when i turn it up, it shuts off. Like its shorting out. I have a 2070 yamaha reciever, that did the same thing sutting off after turning the unit on,and turning it up. It had a bad master volume contol.
Keep the pre amp at least 4 feet away from the amp this will solve the problem promise
When too close a magnetic field is created and shuts off the amp
You will have to change the volume controller and its circuit board.
F150 Accessories
SOURCE: MY YAMAHA RECIEVER KEEPS SHUTTING OFF
The unit is going into protection mode. The message is a generic one and usually means that the output section is drawing too much current and has been shut down. Defective speakers can cause this, but in this case, I suspect that there is a problem in the front end that is allowing DC current to pass to the output circuits. This will cause a problem that will shutdown the system. Yamaha designs are not the most straightforward nad I would not suggest you attempt this repair without prior repair experience. Take this to a service center and request a detailed repair estimate and report the results here. Armed with that info, we canguide you further.
Dan
SOURCE: My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
