Sound has stopped working
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law.
The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it.
This happened to me and this was the fix, odd but true.
Also see if there is a turn by turn vol level in settings.
Hope it works for you.
