Motor is 3-4 years old!
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
SOURCE: how do i tear down impellar housing on ao smith
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
SOURCE: PUMP TRIPS BREAKER, BUT SHAFT ROTATES FREELY
Probably not. Take the capacitor off and inspect it for physical damage and if it looks ok take it to an electric motor shop for testing. Assuming it is ok your motor will probably need work or replacement.
