Bearings are seizing and not spinning freely. That is common when a shaft seal starts to leak & goes uncorrected.
The sound you are hearing are the failing bearings. This will also create the symptoms you described.
Replace the bearings & you will have the problem corrected.
There are two of them: front and rear - both are different sizes. They will look similar to this:
SOURCE: how do i tear down impellar housing on ao smith
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
SOURCE: We have a Hayward Motor A.O Smith Model C48J2N131
you need to lube the motors shaft with electric motor oil they sell it in any hoby shop
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
