I have a Lexmark X5470 it is not working. The power light comes on but the control panel menu doesn't(the words on the menu isn't displaying). The screen is blank and only the LCD light is on. Also the buttons dosen't work. I've tried to press the copy, scan,and the fax neither responsd nor does the menu button or any other button. I've tried everything but nothing works.The printer comes on and light up the menu screen but the words for the menu option is blank and the buttons doesn't work. I've tried contacting Lexmark techs, but my warranty expired and the technician gave me instructions on rebooting the printer and that wasn't successful, unless I didn't follow the instruction well. Please help I need my printer for school and other reason.
A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
1.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
4.
Reboot your pc.
5.
6.
list again, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at .
Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
A
If
1.
2.
seconds).
2.
3.
4.
Reboot your pc.
5.
6.
list, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6.
Try to rebrick you printer by pulling out power supply, black box where the
seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
A
If
1.
2.
seconds).
2.
3.
4.
Reboot your pc.
5.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
A
If
1.
2.
seconds).
2.
3.
4.
Reboot your pc.
5.
