Question about Jensen NAV104
Screen displays #1 in the center of the screen and 2,3,4,5 inthe four corners
    New Friend:
Ding ding ding, Thanks Joeb
Posted on Nov 19, 2015
    New Friend:
It is calibration, hold your finger on the x until it moves to the next number.
Posted on Aug 25, 2012
6ya staff
SOURCE:
How can i adjust horazantal and vertical screen monitor size so i may fill full screen?
In Windows:
1) Click the "Start" button lower left hand corner of the screen, or the Windows key on the keyboard,
2) Choose "Control Panel",
3) Choose "Display"
4) Choose "Change Resolution", and select one that gets you where you want.
FixedYa !
Feb 25, 2015 | HP Desk Top Access Center DK985A
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Need car stereo code for honda accord 1995
stereo codes for Honda
Method 1 (all applicable models except '03-07 Accords with the navigation system)
1. Turn the ignition switch to ON (II).
2. Turn on the audio unit, and make sure you see stereo COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
3. Turn off the audio unit.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
Method 2 ('03-07 Accords with the navigation system)
1. Turn the ignition switch to ACC (I).
2. Turn on the audio unit, and make sure you see COdE in the upper display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the top halves of the SEEK/SKIP and CH/DISC bars, and then press and release the PWR/VOL knob. This display toggles between two screens. The first screen displays a U and the first four digits of the serial number (for example, U2200). The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
5. Call Honda Dealer for Radio Code.
6. Use the TUNE knob to enter the first four digits of the anti-theft code into the audio unit. (Ignore the last digit; it's not used.) When you turn the TUNE knob, COdE disappears, and a single digit is displayed. Turn the knob left or right to select each of the anti-theft code digits. When you press the TUNE knob, the system beeps and accepts each digit as it spells out CODE on the display.
https://radio-navicode.honda.com
May 04, 2010 | 1995 Honda Accord
I need to get a radio code for a 1999 honda accord
2. Turn on the audio unit, and make sure you see COdE in the display. If you don't see this message, pull the backup fuse for 1 minute, and then go back to step 1.
4. Press and hold the 1 and 6 preset buttons, then turn on the audio unit. The display toggles between two screens:
- The first screen displays a U and the first four digits of the serial number (for example, U2200).
- The second screen displays an L and the last four digits of the serial number (for example, L0055). Ignore the U and L, and write down all eight digits.
If this don't work, definitly you need to call Honda delaer using your VIN.
Hope this help.
Mar 18, 2010 | 1999 Honda Accord
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Jensen NAV104 Logo
190 people viewed this question
Top Jensen GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Jensen GPS Expert? Answer questions, earn points and help others
