Cell Phones Logo
Anonymous Posted on Aug 12, 2012
J105 keypad ways
Keypad no. 5 and enter not functioning
Computer Repairing
Level 3:
  • Cell Phones Master 14,641 Answers
  • Posted on Aug 13, 2012
Computer Repairing
Cell Phones Master
Level 3:
Answers
14641
Questions
0
Helped
719450
Points
53082
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Service mode for Maytag MFX2570AEM3 refrigerator
How to enter service test mode in a Maytag refrigerator with electronic controls
Service Test Mode:
The service test functions are performed using the refrigerator display and keypad.
Enter the Service Test Mode by performing the following sequence of events.
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers.
hope this helps.
also may find more info at repairclinic.com site
Sony ericsson j105 keypad botten back * # not working...
Open the mobile cover and open the keypad and clean it if it was junked nither u should auy a new keypad
MY KEYBOADS DOEN'T FUNCTION,WHAT CANI DO?
Depending of course on your full model number, you may need to replace the membrane keypad or the control panel frame assembly, which comes with a new keypad.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
4helpful
J105i keypad problem
Aug 12, 2012 • Cell Phones
2helpful
3answers
Service Code - Fucntion Problem within the copier - Code SC541 Serial # of Mach J0122404128
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
1helpful
2answers
C470
this is a fuser unit error code. reset code in following way.
1, turn off power. 2, hold down 0 & 8 keys. 3, turn on power still holding keys down until beep is heard. 4, enter 400 on numeric keypad. 5,press start button. 6,enter 0 on numeric keypad. 7,press enter icon on the main lcd display.8,cycle power
2helpful
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • 0helpful
    I want to find out how to set up our Canon CFX0-L4000 fax Machine
    CANON CFX-L4000 UNOFFICIAL MANUAL
    RIGHT KEYPAD
    FUNCTION
    SET
    01 DATA REGISTRATION
    02 DELAYED TRANSMISSION
    03 POLLING
    04 MEMORY REFERENCE
    09 REPORT
    11 UP
    13 +
    14 LEFT
    15 SPACE
    16 RIGHT
    18 CLEAR
    19 DOWN
    Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
    Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
    EG. Setting a speed dial number:
    FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
    EG. Setting unit telephone number
    FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
    EG. Retransmit from memory (assumes memory light is on)
    FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
    EG. Delayed transmission
    place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
    for full guide you will have to search and purchase one.
    Top Cell Phones Experts
    ADMIN Andrew
    ADMIN Andrew
    john h
     Mikey
    Mikey
    Are you a Cell Phone Expert? Answer questions, earn points and help others
