How to remove
The water valve is located in the "outside rear lower of unit" where the water pipes go into the unit for water source feed, remove the plate, the valves lift up and out or twist and up, remover the 2 wires on the valve and replace the valve, repeat the removal in reverse. PLEASE ENSURE YOU HAVE WATER SHUT OFF AND POWER PLUG """"REMOVED""" FROM THE POWER POINT. Any further issues, please contact me at [email protected] and I will guide you through the process. Russ
Welcome to FIxYa.com
THERMOSTAT REMOVAL HINT: Removal of the thermostat would have an adverse effect causing a lowering of cooling efficiency. Do not
remove the thermostat, even if the engine tends to overheat. 1. DRAIN ENGINE COOLANT 2. REMOVE AIR CLEANER CAP WITH AIR CLEANER HOSE 3. DISCONNECT ECT SW1TCH CONNECTORS 4. DISCONNECT ENGINE VIRE PROTECTOR FROM WATER INLET AND RH CYLINDER HEAD Remove the 2 nuts, and disconnect the engine wire protector from the water inlet and cylinder head. 5. DISCONNECT WATER INLET PIPE FROM WATER INLET AND LH CYLINDER HEAD a) Remove the bolt and disconnect the inlet pipe from the water inlet. b) Remove the O-ring from the inlet pip e. 6. REMOVE WATER INLET AND THERMOSTAT a) Remove the 3 nuts, water inlet and thermostat. b) Remove the gasket from the thermostat. INSPECTION INSPECT THERMOSTAT HINT: The thermostat is numbered with the valve opening temperature. a) immerse the thermostat in water and gradually heat the water. b) Check the valve opening temperature. Valve opening temperature: 80 - 84CC (176- 183 deg f) If the valve opening temperature is not as specified, replace the thermostat. c) Check the valve lift. Valve lift: 10.0 mm (0.394 inch) or more at 95CC (203 deg f) If the valve lift is not as specified, replace the thermostat. d) Check that the valve is fully closed when the thermostat is at low temperatures (below 40CC (104CF)). if not dosed, replace the thermostat. INSTALLATION 1. PLACE THERMOSTAT IN WATER PUMP a) Install a new gasket on to the thermostat. b) Align the thermostat jiggle valve with the upper stud bolt and insert the thermostat in the water inlet housing. HINT: The jiggle valve maybe set within 15 deg of either side of the prescribed position. 2. INSTALL WATER INLET Install the water inlet with the 3 nuts. Torque: 8.0 Nm (80 kgf-cm, 69 inch lbs.) 3. INSTALL WATER INLET PIPE a) Install a new O-ring to the water inlet pipe.
Thank you for using FixYa.com
Regards, Lee Davidian
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
