When you go through the set up you will see 12:00 flashing. Push the set button again and you will see 24:00 flashing, select this and move on and should be good
Gabe Barrow, Barrow's Jewelers
On a different Skmei model, you can toggle the 12/24 settings within alarm settings. This also changes the setting for displayed time.
As I suspect that a lot of their models use the same internal module, it's worth a try.
Casios have 2 time modes.The 12 hour mode (am,pm) and the so called "military time" 24 hour mode.When your set time,date,year there is an option 12H or 24H.Choose the 12H by pressing the lower right button when in setting procedure,I say again.Press tthe upper left "ADJUST" button to finish the procedure.
Simply advance hands 12 hours forwards (clockwise). Just pull out crown to the time setting position and turn the watch hands forwards if the date is changing before midnight. If the date is changing after midnight - turn the hands 12 hours backwards. Don't do this when the actual time is between 10pm - 2am.
Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
Make note of the hour if you don't have another clock handy
Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
quickly press the bottom-left button twice. then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
