Arris DCT700 DTV Receiver Logo
Anonymous Posted on Aug 12, 2012
Motorola DCT700 won't power up.
I unplugged the unit (AC line) and when I plug it back in the power light flashes amber, then red, then no light. Can't find this in any trouble shooting info. Any ideas?
  • Anonymous Aug 13, 2012
    SOme more details: The transformer was quite warm. The results were the same whether the cable lead was attached to the unit or not.
David Payne
Level 3:
Top Expert:
  • Arris Master 14,162 Answers
  • Posted on Sep 15, 2015
David Payne
Arris Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2994915
Points
455836
toadrules
Level 2:
Novelist:
Scholar:
  • Expert 192 Answers
  • Posted on Nov 14, 2013
toadrules
Expert
Level 2:
Novelist:
Scholar:
Answers
192
Questions
0
Helped
52155
Points
256
Its working correct... thats sounds normal
now you just need to wake it up. turn it on using the remote supplied by your cabe operator. if anything it may be your remote that isn't working. does a "cbl" light or anything light up on the remote when you press the cable box power button? if not try to find out how to put it in cable mode and try again.
wish i had more info
good luck
Amber light is on
Unplug the power cord and the USB cable from the rear of your printer. Wait one (1) minute. Plug the power cord back in. Plug the USB cable back in. Re-start your computer. In most cases, this will solve the problem. Good luck.
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
1helpful
Red power light flashes on an LG 8000BTU AC
Called LG. It's an alarm that's preset on your unit to chime at regular intervals (300-500 running hours) to remind you to clean your filter. Turn the unit off, unplug it, wait a few minutes, and turn it back on. All done.
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
1helpful
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
3helpful
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
Top Arris Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
