SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
SOURCE: No Video only sound with Onkyo TX-SR605 7.1, tried everything, HELP!!!!
same receiver same problem. at least ou're not alone.
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
SOURCE: How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
