SanDisk Sansa E280 MP3 Player Logo
Posted on Dec 18, 2008
Key Lock Sansa e280
OK, I have a Sansa SanDisk e280 Music Player that is broken...whenever I turn it on, the screen says "Key Locked" and right below it"System Shutdown"...I have posted a problem like this and the best solution I got was to go into "Recovery Mode" and update my firmware...I did this and I still got the "Key Locked" and "System Shutdown" dialouge...I need to know how to get it out of this mode and into its normal "state"...also, when I plug it in to recharge I get the "Key Locked" and "System Shutdown" dialouge also...Please Help!!!
  • respecter
    respecter Dec 18, 2008
    is there a way to just reset the whole thing?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 27, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
789
Points
9
On the top is a switch that says lock /unlock ......... switch to unlock
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1165
Points
Have you tried to unlock from the lock switch on the back of the player? the switch is next to the headphone input, Hope this helps.
1helpful
I turn my sansa 280 on, it displays "key locked, system shutdown
there is a hold button on the top of your device. move it to the left and then turn it on.
Complete freeze to my sansa e280 8.0gb sandisk
take the back of the unit off with the very tiny 4 phillips head screws and remove the battery, then put it back in and see what happens, if it's no netter buy a new battery from Amazon there short money and come in a kit with 4 new screws and a screwdriver
''Key LOCKED. System Shutdown.'' Problem
Disengage the hold/lock button on top of the player.
My sansa 250 e
try running your sansa out of battery so the screen shows [to low of battery] then plug in your sansa to your computer and resync your music
3helpful
3answers
Key Locked
Sounds to me like your hold switch is on. Have you tried sliding your hold switch on top of the player, next to the headphones jack to the off position?
My sansa might have a virus
I would suggest that you reformat it.
To format it open up a My Computer window, and right click on theremovable storage deice that you using and then click format.
2answers
My e280 sansa mp3 player is not working.....help please....
There is a problem with the device firmware itself..you can try to reset the player by holding the power button down for 15-20 seconds or until it resets....the latest firmware for the e280 resolved much of the freezing issues....also there are two modes for you to use the e280 the msc and mtp.....try deleting in mtp mode....if that doenst solve it...just go to the sandisk site to get a firmware upgrade done...and that would solve the proplems..
Screen turns weird colors when trying to play a video
You can press and hold the power button for 20 seconds, instead of removing the battery.
As for the other issue, there is not any RAM on the MP3 player to buffer the video, so its best to keep the video in clips around 10 minutes.
Best of Luck.
1helpful
My Sansa E280 turns blue but no Sandisk screen comes up.
I'm SOOOOOOO excited i got it to work again. I took off the back cover and removed the battery while the scroller was on and blue, then right above the battery there is a black rectangle thing that was not flush with the rest of it. I pressed that in turned it on, and bam it was good to go. I hope you all have as good of luck as I have had. Let me know if it worked for you!
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
