Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
E15 error code
My stove is beeping with an E 15 error code ...
  • Official Brand Answer
  • 4,342 Answers
You have an error between the control board and electronic oven control. 1. Test the harness and connections from EOC connector P16 to Oven Relay Board J2. 2. Replace the Oven Relay Board. 3. Replace the EOC.
Posted on Aug 14, 2012
6ya staff
SOURCE:
How to fix an error E 15 code on electrolux induction range
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Aug 31, 2015 | Electrolux Kitchen Ranges
Stove top error code E 15
Thank you for your post, friend!
From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
Feb 15, 2015 | Electrolux Cooktops
Fix e 15 error code on electrolux induction range model ew 30is6cjs have turned off barker to allow for reset. still get error code
Good Morning friend, thanks for your post!
I see your Electrolux range is displaying "E15" error code and you have reset your appliance but continue to receive the message. An "E15" error code stands for ESEC (Electronic Surface Element Control) self-test failed which could be a possible issue with your relay board or UIB (User Interface Board). I suggest seeking assistance from a technician to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 26, 2014 | Electrolux Kitchen Ranges
Why is there an "E" and :"15" on my Electrolux Induction Stovetop? Originally it was beeping but then it stopped.
Good Afternoon Jane - Generally, error code E15 means that the unit is experiencing a power board failure. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Jun 25, 2013 | Electrolux Stainless Steel Induction Slide...
Error code 15
What is the make and model number of your unit?
Feb 09, 2013 | Dryers
Hotpoint MODEL WM75PR error code E15
E15 "Check Outlet Pipes". Normally this is a blockage in the pipe or the filter connected to the drum.
Error code 15: Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not
blocked.
What you need to be sure of, is whether when the error telling you to check for blockages in the outlet pipes happens, it's actually an accurate indication of the fault. I dislike these stupid error codes as they often fire off erroneously and cause no end of trouble.
It can also mean a faulty control panel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2009 | Washing Machines
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
5,236 people viewed this question
Top Electrolux Kitchen Ranges Experts
Marvin
Marvin
Eric Rotmil
Eric Rotmil
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
