SOURCE: Can't Change the background of the screen
The Touch series uses the Touchflo userinterface on top of Windows Mobile and has it's own background-wallpaper setting. You probably changed the "normal" Windows mobile background picture, which is hidden "behind" the Touchflo interface.
To change the Touchflow wallpaper select the "Settings" icon in the scrollable bottombar (which leads to the Touchflow settings) instead of the "Start Menu | Settings" shortcut (that's the "normal" Windows mobile settings)
SOURCE: I cannot get the Qwerty Keyboard on my HTC Touch HD
Hi I just got this phone yesterday - its really awesome. I had the same problem - to change the keyboard just press the keyboard button on the bottom like you usually do to bring it up, then press the little up arrow next to that button. This gives you a selection of keyboards to use, they are much better as they are TouchFlo 3d keyboards.
SOURCE: HTC Touch HD alarm problem ?
click on the alarm icon, click on the bell which takes you to where you need to be able to change the tone
SOURCE: I CANT DELETE MUSIC FILES FROM MY HTC Touch HD
YOU HAVE TO CONCECT ON COMPUTER WITH ATCTIVE SINC AND YOU CAN DELETE OR AD FROM THERE.
SOURCE: can't play java on my htc touch hd
In general WinMo doesn't support Java. You need application called Esmertec JBed which will run JAVA on your device.
