Magic Chef 31000 Gas Kitchen Range Logo
Posted on Dec 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan in oven will not shut off, F-4
Magic Chef, model #59F5TXW - single oven - the fan will not shut off and when you turn the oven to heat up the error code F4 shows up. Can you help me?
Thanks!
Jan
Anonymous
Level 3:
  • Master 794 Answers
  • Posted on Sep 19, 2011
Anonymous
Master
Level 3:
Answers
794
Questions
0
Helped
285196
Points
1864
Hi jsachse,
The F4 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
1helpful
Oven not heating
If your oven is gas, like it says up top, then your ignitor is bad...
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
My Magic Chef 21MS Natural Gas Oven will not heat up in oven. The top burners are fine.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
1helpful
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
2answers
My oven won't work
Replaced ignitor on mine, fixed it.
5helpful
4answers
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
