This is software problem i.e windows try to reinstall your windows and format all the partition this is usually occours by viruses . it takes hours at startup and at launching any app.
for backup your files reboot your computer and press f8 key and run computer in safe mode copy all the important files on your flash drive
SOURCE: i m having problem of lots of hanging ups in dell inspiron 6400
Dell inspiron 6400
01. If the Laptop is under Warranty, you will get the technical support from the wep after typing the following website :
http://support.ap.dell.com/support/supportrequests/api/create.aspx
02. Frequent hanging may be due to Harddisk crash or latest antivirus patch not updated.
03. Please update the latest antivirus patches and run for any virus checking.
04. Over phone you will get Gold Technical support from Dell Service Support Team.
05. If Dell team is not able to solve the problem, either they will replace the Laptop or send some local Dell Authorized service engineer to give solution for the same.
06. On Daily basis, please take a backup in DVD CDs-R/W (4.7 GB Memory) after selecting the files to be backed up daily or weekly.
07. Better advise to replace the Laptop or Replace the HDD from Dell Team.
SOURCE: CD/DVD tray opens on its own- Dell Inspiron 510m
The lock on the drive is failing, you'll need to replace the drive.
http://cgi.ebay.com/DVD-RW-drive-Dell-Inspiron-300m-500m-510m-600m-610m-M20_W0QQitemZ280435221123QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item414b3de283#ht_2162wt_1165
SOURCE: I had just purchased a
hello miss sally, hi, the operating system error may be caused by a faulty hard disk or hard disk connection cable, and the hanging thing is caused by a faulty memory module, so check then out first, swap a new memory module, and for your hard drive, take it out from your laptop and use a PC to test the drive (applicable only if your hard drive is sata.)
SOURCE: dell inspiron 1525 will not
RY THIS FIRST Hold down FN KEY and POWER Button for 3 Secs to go in Diagnostics Mode (works on almost all Dell Laptops) and run the full test you'll find something wrong if its a internal issue (even if its a hard drive issues), see if that fixes it, but I'd check the CPU HS Fan (the slots where air comes out)just blow in there and you'll see dust come out, clean it out with Air Can or Air Hose at 60PSI to prevent it blowing your blades up on the fan. If its not a hard drive or cooling issue, might want to try the Memory check (Dell has laptops have memory issues from time to time) Hope this helps!
SOURCE: my dell inspiron mini 10 notebook using window 7
Laptop Slow
Run System In Safe Mode:
To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop.
1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem.
Now you are able to easily diagnosewhy Windows laptop starts up very slow.
b>
Limit your Startup list:
A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below.
1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done.
b>
Uninstall unwanted program:
Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps.
1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done.
b>
Scan System for Viruses:
Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program.
b>
Run Disk Clean Up:
Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given:
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up.
b>
Defrag hard disk:
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter.
b>
Defrag Registry:
You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
