Unit will take a charged battery from another unit, and works fine on a charged battery. will not run on ac adaptor, ac light flashes when plugged in the wall and when you try to charge battery.
SOURCE: I have a toshiba satellite A205-S4617. The battery
the laptop overheated and the motherboard is damaged and need replaced
SOURCE: Battery will not charge. AC power LED does not come on when AC power adapter connected.
You may have a faulty adapter. Check the connector with a multi-meter, the voltage reading should be slightly higher than the voltage that is printed on the label on the back og the power adapter.
If the light on the power adapter does not light up when you plug it into the mains, then it is definitely faulty and you need a new one.
SOURCE: Will not recognize AC POWER, Running from Battery only- now battery is dead.
The adapter might be faulty
Check the adapter with multi-meter, the voltage reading should be slightly higher than the voltage output that is printed on the label on the adapter.
SOURCE: I have a battery issue. The computer works fine on
Your charging IC is damaged, all you need do is get your system to an expert who will get it fix. it is not a user serviceable issue. good luck
Testimonial: "Thanks. I couldn't figure out what the deal was...lol."
SOURCE: I have a Toshiba Laptop,
hi,
here is what you can do...
I have a video clip below (courtesy of youtube) to guide you on how to diagnose your laptop.
The video explains what you can do.
Hope this helps your problem.
Don't forget to rate me. Thanks...
Regards,
John
