you have to remove the cover, un-plug the power cord= un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
Belts. Underneath machine. Replace both. Also make sure motor slides back and forth easily. Take off front to check that. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
