Dell 962 Photo All-In-One InkJet Printer Logo
Anonymous Posted on Dec 17, 2008
Dell a940 cant find aio center
I cant find where to set scan settings, keeps telling me to go to aio center but there is no aio centeron my program search
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
103
Points
I reinstalled the driver
How do i scan and email a document using the a940 printer
On the printer press scan, then press options, move the right arrow key. Select e-mail and press select button. Also, go to start menu, go to all programs, Dell printer, then select DELL AIO Printer A940, then select Dell All-In-One Center. On the Scan box on the drop menu select e-mail. All set, scan from printer to e-mail.
1helpful
I wanna install de program of my printer dell a940 in my sony laptop
I believe when you say you want to install the program on your Sony laptop you mean that you want to set up the software for the printer.
Please find the link below to the software:
http://download.cnet.com/Dell-AIO-Printer-A940/3000-2116_4-75489.html
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A940&os=WW1&osl=en&catid=&impid=
You can download the drivers from any of the 2 links.
Please let me know if this information helps.
Please rate me if the information provided was helpful.
I recently got a new Dell computer and kept my Dell AIO 922 printer, but now the icon is lost, I cannot scan. However, I can print, but that is about it.
Do you still have the Dell AIO 922 Drivers and Utilities CD? If so, you can reinstall it on your new Dell PC with the Drivers and Utilities CD. Although you are able to see this printer in your list, the other components are missing such as the scan and fax options. If you have already reinstalled it using the CD, you should see the All In One Center under the Start Menu/ All Programs/Dell Printers/Dell AIO Printer 922 and the All In One Center should be showing there. You can right click on the All in One Center and select "send to" and choose desktop to create a shortcut or icon on your desktop. Your options for scanning and faxing should be showing here. Hope that helps!
2helpful
How di I scan using my 946 dell printer
Original Maual can be downloaded from http://support.dell.com/support/edocs/systems/prn946/en/index.htm Using Your Computer 1. Click Start® Programs or All Programs® Dell Printers® Dell AIO Printer 946.
2. Select Dell All-In-One Center.
3. The Dell All-In-One Center opens.
4. From the Send scanned image to: drop-down menu, select the program you want to use.
5. Click See More Scan Settings to customize your scan.
6. When you finish customizing your settings, click Scan Now.
7. When the printer completes scanning document or image, a file containing is created in the selected application.
Scanning
Which Dell Printer are you using?
Go to Information about Dells Inkjet, All-In-One Printers, scroll down and click on the owners thread for your Dell Printewr. Instructions on how to install are there.
Rick
2helpful
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
1helpful
2answers
Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
