The computer wont come on and blinks red with nine beeps
SOURCE: HP Compaq 6005 Pro, nine beeps
9 BeepsNine beeps means that there has been an AMIBIOS ROM
checksum error. Literally, this would indicate an issue with the BIOS
chip on the motherboard. However, since replacing a BIOS chip is
sometimes impossible, this AMI BIOS issue is usually corrected by
replacing the motherboard.
Use utility tool like RegInOut to repair corrupt registry files and keep your computer safe from being damaged.
Suggested Resolution
Solid green
Power is on, and the computer is
operating normally. On the desktop computer, a solid green light
indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
With 9 beeps, you probably have a BIOS error. Is there a specific pattern to the beeping like 3 beeps, 2 beeps, 2 beeps, 2 beeps?
