Computers & Internet Logo
Anonymous Posted on Aug 10, 2012
TALLY 5.4 showing error....Exiting TALLY! Incorrect version. Data of INCORRECT version(7). Can only run version 5!
It was working when I worked the first time..but then when I opened tally 7.2, i think all files got extracted and transferred to 7.2, and now the 5.4 version is not working...it's showing the above message...Pls help...!!
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 31, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2057
Points
7
Koee mujhe batayega ki me apna data 9.2 se 7.2 me transfer karna chahta hoo aur ye baut jyada jaroori hai mere liye but jab me 7.2 ko open krta hoon toh sab compny ki list hoti hai but jo company tally 9.2 se utthaee thi wo wanha par show nai hoti hai aisa kue??????
Pls Help me me baut problem me hoon!!!!!
[email protected]
09310947557
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Mar 22, 2008
SOURCE: How to Export trial Balance from Tally 9.2 version to Excel sheet
you select the trial balace--and press Alt+E or click export---then the export details screen came,
Language: Default(all language)
Format: Excel (spreadsheet)
Output file name: trial bal.xls (any name you select)
Excel (spreadsheet) formating: yes
other details you select and accept the screen. then minimise or close the Tally, you open the tally file name at my computer. at the time you can see the file trialbal.
Anonymous
  • Posted on May 26, 2008
SOURCE: error in tally 7.2
hi
you have have tried ctrl+alt+r
plz copy your data any other folder and delete this file tr01296.500. and have retried ctrl+alt+r and rewrite this company
Anonymous
  • Posted on Aug 24, 2009
SOURCE: Memory violation in tally 7.2 release 3.13
in some ledger we see the problem softare exception c0000005(memory access violation)
Anonymous
  • Posted on Jan 02, 2010
SOURCE: memory exception error in tally 7.2
I am facing this error in tally 7.2 memory exception error in tally 7.2 Pls help with a possible solution.cheeku
Anonymous
  • Posted on Apr 22, 2010
SOURCE: Memory Access Violation
how slove memory access violation
EXITING TALLY!! INCORRECT VERSION. DATA OF INCORRECT VER.11 CAN ONLY RUN VERSION 10
you cant operate tally with the other version data of tally
you will have to migrate the data
the migration data option is there in tally
EXITING TALLY!! INCORRECT VERSION. DATA OF INCORRECT VER.(8) CAN ONLY RUN VERSION 7
check if the version you are using on both the computers are same. If they are same also check for the release. If there is difference in the version and relase it wont work.
Try migrating the data from lower version to higher version or use same release on both the pc
83helpful
5answers
EXITING TALLY!! INCORRECT VERSION. DATA OF INCORRECT VER.(10) CAN ONLY RUN VERSION 11
In Tally ERP9, try the following:
Start Tally.
Press Ctrl+Alt+R. This will rewrite the data.
Now select the company. Confirm for rewrite. Take Backup.
After rewrite, you should be able to open the data and work.
Note: Please have a backup of the data before doing the above, just in case something goes wrong.
All the best.
3helpful
2answers
I have problem vit tally. i have multiuser tally.erp9 error massage is incorrect version data of incorrect version (6), can only run version 5
You either need to upgrade your version of Tally.ERP9 or your need to rewrite your data.
I would suggest you to rewrite your data using the following method.
Take a backup of your data.
1. Run Tally. 2. On the select Company screen press "Alt +R" 3. Select your company 4. Rewrite your data.
It would work now.
Rishabh
1helpful
Using tally 5.4 ,it is showing exiting tally.............,,,incorrect version
This problem occurs when u use previous version of data in 5.4 version or it may be a problem of tally.exe replace this file with fresh tally.exe
4helpful
Exiting Tally, Incorrect Version, Data of INCORRECT ver(8), Can only run version 7
I CANT PRESS CTRL+AL+R SINCE IT GIVE ME THE ABOVE MESSAGE NOTHING CAN BE PRESS PLEASE HELP
36helpful
2answers
Exiting tally incorrect version (10) during selecting the company after inporing the data
exiting tally incorrect version data of incorrect version 10 can only run version 9
43helpful
4answers
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
CAN ONLY RUN VERSION 9!
Grand Canyon Tech
Grand Canyon Tech
