Ricoh Aficio 1035 Copier Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ricoh Aficio 2027, Service Code 320
Hi, When I turn the machine on it tells me "Functional Problem within the copier. Turn operation switch off then on. If the error appears again, call service. SC320.
I have turned the machine off and on, unplugged it and still get the same message. Please help.
  • misrael Dec 17, 2008
    Thanks, it cleared for a few seconds but then came back. How expensive is a new laser motor? Is it something I can install or must I call a pro?
Everett Lin
Level 3:
President:
  • Ricoh Master 990 Answers
  • Posted on Dec 17, 2008
Everett Lin
Ricoh Master
Level 3:
President:
Answers
990
Questions
Helped
434408
Points
3069
Dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
  • Everett Lin Dec 18, 2008
    The motor price I'm not sure, but by my experience the price around $ 70.00 us dollar, If you are handy man why don't try it.
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Functional problem
change the td sensor below the developer unit or if possibly change the complete developer unit
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
1helpful
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
7helpful
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
4helpful
I turn on my ricoh aficio 2027 this code SC670 APPEAR
670 D Engine response error After powering on the machine, a response is not received from the engine within 30 seconds. • SBCU installed incorrectly • SBCU defective • Controller board defective
You can try to reseat the connectors on those 2 boards, if that doesnt work you may need to replace those boards.
7helpful
3answers
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
2helpful
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
