Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
