indicates reed or poppet valve problems in the head/s
there is a non return valve before the tank but if the head valves springs are broken or damaged , it pumps air in and out or from one cylinder to the other
Sounds like part #27 is worn. Replace # 24 24 A 24 B and 24. the cylinder may be worn. Perhaps depending on the age and time and labor replace with new comp. maybe Dewalt.
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Your compressor is most likely made by Campbell Hausfeld. The oily substance could be leaking from the capacitor on the motor. Remove the cover and examine the capacitor for failure. There is a value printed on the cap. (uf) The cap must measure to within 95% of printed value. A failing capacitor will cause the hum that you are experiencing.
where can i get a free repair man so i can take it apart
