Trying to hook a ps3 with component hookups (green / blue/ red) and can't get the tv to switch from svhs (s-video) to component because I don't have the remote. any help will be appreciate!!!!
SOURCE: CVI connection
On a Philips TV the only way I know to switch to any of the inputs is by scanning using channel up or down. This model is capabable of 480P input only at the CVI/Component input. This is not a HD television. It is only a EDTV (enhanced definition) if you try and input anything iver 480P IE: 720p or 1080i, the double image and/or lines is what you will get.
SOURCE: Philips model: 32PW9523/75
buy a 1 for all remote quite easy to get hold and not too expensive!
SOURCE: Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
SOURCE: #27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
SOURCE: I bought a used Philips tv, model # ocv625c123 ,
I found the switch on my SAT box to switch it fro m ch 3-4. I still don't know why the tv won't go to ch 3. But it doesn't matter now.
