Western Digital Caviar WD800BB 80 GB Hard Drive Logo
A
Anonymous Posted on Aug 09, 2012
Wd800 jumper settings on 8 pin drive - Western Digital Caviar WD800BB 80 GB Hard Drive
Lawrence Oravetz
Level 3:
  • Western Digital Master 10,558 Answers
  • Posted on Aug 16, 2017
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2694829
Points
29284
3 Related Answers
Christopher Thrash
  • 425 Answers
  • Posted on Dec 03, 2009
SOURCE: how do i set the jumper on wd800 caviar as a slave
Here you go
Anonymous
  • 3600 Answers
  • Posted on Mar 21, 2010
SOURCE: Do you have the jumper setting for hard driveWD800
I do what seeting you looking for? slave master here is thier web page for the information.
http://wdc.com/wdsearch/search.aspx?sq=wd%2080%20hard%20drive&sl=en-US&sc=
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Oct 27, 2010
SOURCE: I have a Western Digital
You can refer to this:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
2answers
3helpful
2answers
Slave jumper settings for a Maxtor N256 Hard Drive
I have never personally seen one but most drives are the same for the type of jumpers installed. See if this helps you:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
3helpful
2answers
2helpful
Need jumper setting for slave drive ide
If the drive is the Seagate Baracuda series, then simply remove all the jumpers from 8-pin jumper block and it will be a Slave drive.
If you want any other settings, the jumper settings are described here:
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
2answers
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
On a older system gateway w/ windows 95 hard drive went south I put another in, the two drives; org,wdcaviar 24300, the newer wd caviar wd800 are jumpers same
Jumpers on the newer Western Digital drives are different. If the drive is a single, then you should not have any jumpers on. If it's going to be a master and there's a slave, the jumper goes on the middle two pins of the five sets
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
