If the battery is low in my infoglobe 3000, will it display the caller id numbers? Where do I buy replacement batteries. can you tell me what batteries to buy? This was a gift and received no manual with it so it is very difficult to work out any problems with this globe. my husband loves it because he can see it. it tells me low battery
SOURCE: BLUE - Olympia InfoGlobe Digital Caller ID Unit
i NEEDED TO KNOW IF IT SOMEWHERE i CAN GO TO PRINT OUT MANUAL FOR THIS ITEM. tHANKS.
SOURCE: olympia infoglobe
Funny that I came across this. I just now fixed this exact problem. This unit had failed after an electrical storm. Solution found elsewhere suggested removing the batteries and unplugging the A/C adapter for 10 minutes. (I waited 30). Reinstall batteries and reattach A/C adapter. Buttons worked to get to the erase memory option, which I did. Infoglobe is now functioning properly. This is also the instructions for clearing the "eeprom error" readout that many infoglobes exhibit after a power surge. Good Luck!
SOURCE: Olympia Globe Caller ID
I just printed a manual in pdf form go to,http//smarthome.com/manuals/5109.pdf
SOURCE: how to change time on Olympia Infoglobe caller id
I have the manual and can tell you what it says:
(this worked for me last year when we went off daylight savings, but for some reason, It doesnt seem to work anymore. I can't imagine that I did anything different then. You can try, though.)
Enter (or leave) the Demonstration Mode by pressing the right key for at least 1 second.
Then, by pressing SELECT key, you are SUPPOSED to be able to scan a menu which lets you pick date format, time format, etc.
This no longer works for me, and the instructions also have a contradictory comment that says the SELECT key is disabled in this mode. But perhaps this will work for you.
I would also appreciate instructions if anyone knows what I am doing wrong.
SOURCE: caller ID does not work
try going to your phone settings and go to calling settings you should be able to disable and enable it there.
