Question about Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC
Adjusting date/time windows xp - Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC
  • Microsoft Master
  • 27,725 Answers
Click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab (right click on the time to adjust)
hope this helps
Posted on Aug 10, 2012
6ya staff
SOURCE:
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
Sep 29, 2018 | Time Computers & Internet
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Jan 20, 2017 | Computers & Internet
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
My computer time and date are in another language and time and I can't figure out how to change them to english. Have tried adjust time date.
If you are opening the time/date from the task bar, instead try going to the control panel and open the Regional Settings applet. In there you can set time zone and other settings that may help.
Mar 08, 2011 | Microsoft Windows XP Professional
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Unable to update or sychronize with time.windows.com
you need admin\administrator rights to change anything on vista. it is suppose to be more secured than Windows XP.
administrator /user is power user rights, which don't have rights to change system setting, but you do have rights to install certain program.
login into the machine as administrator and provide the corect password.
Apr 28, 2009 | Microsoft Windows XP Home Edition
Disabling the adjustments of Date & time??
Hi there.
This is the best i can remember about Win98
In Win98, rename the timedate.cpl to _timedate.cpl from your system folder and open command.com in a hex editor and go to the location that is on or around 0x010b36. there you will see a table of DOS commands.
simply rename "time" (and/or "date") to something else (as long as it's exactly 4 characters long!). then bring up a new DOS window and you will see that it only accepts your new command for changing the time and date.
This method, in combination with (renaming timedate.cpl), and
making sure that your BIOS settings are password protected, should prevent virtually anyone who is a non-guru from changing the system time.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Microsoft Windows 98 Second Edition for PC
Date and time error
Hi ya, yeah, my first suggestion would have been to change the CMOS battery, and if you are sure that the one you replaced is new and well charged, then the next thing I would be checking is the time in the system BIOS (rather than using Windows). If you know how to access the BIOS then try changing the time there and then reboot. Power off your computer and turn it off at the wall for a minute or two and then turn everything on again. If your date and time are still correct then you've no more problem (hopefully!). If however, your date and time still change afterwards upon leaving Windows, it is -possible- that there is a 3rd party application on your system that is changing your time/date. If you want to count this possibility out, then take a look at any of the icons in the bottom right of your windows toolbar (beside the clock) to see if there are any new/weird applications running that have anything to do with time or date (some applications adjust your date and time based on your locale and a server on the internet to save you the trouble of ever wondering if your time is right etc.)
Hope this helps point you in the right direction.
Nov 16, 2008 | Microsoft Windows XP Professional With...
Date and time change
It appears that you have the wrong time zone setup. Right click on the time in the taskbar, select Adjust Date/Time.
Make sure the time zone is set for your location.
Lou
Sep 16, 2008 | Microsoft Windows XP Professional
Problem with XP
Ya can adjust your settings to suit ya maximum resolution of ya Video card.. Always ensure you have most up-to-date "Drivers" for your exact type of card. The link below show one how to adjust resolution. www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx
Sep 01, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
