Remote shutter release broke off in shutter release button
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
SOURCE: Nikon N80 w 70-300mm G lens aperture stuck can't separate
The mechunism is jammed. Rather than force things, I would take it to a camera service shop that works on Nikon to unassemble the camera to get to the locking pins. Then they can find the fault and service the camera for you.
Jerry G.
SOURCE: Error msg
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
You have a shutter failure!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
SOURCE: nikon fm10 cannot get shuuter release button to
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
SOURCE: Just inherited a Nikon F100. When the shutter is
Here's the usermanual:
http://safemanuals.com/annexe_INSTRUCTION%20MANUAL_NIKON_F100-_E.htm
on page 101 (Troubleshooting) it mentions the Err message, and the shutter again to release it - According to the guide its a Refer Nikon Service Centre issue.
From how you describe it, it is consistent with there being a problem with lens compatibility. It would be worth checking compatibility (with the chart on pages 32 - 33) - Although if you inherited it "as a unit" I doubt thats the root cause..
Hope this helps
