Blackberry possessed? hi, my bberry pearl 8100 seems to be possessed.. it browses the menus, click, send messages, etc... everytime i try to lock or do something it does the opposite! example, if i try to type something, in the middle of the word, the pearl deletes it and go back to menu.... help please!!!!
What youn need to do is take it to the shop and get it manually fixed as there is nothing you can do unless you are good with electronic you may have to get a master reset
Hi visit Simpleunlocking.com to unlock your Blackberry pearl 8100 mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then they deliver you code to unlock your mobile.
The reason that it's showing that your sim card is invalid is because either the sim card has been deactivated already by your service provider, or the most likely cause is that your
RIM BlackBerry Pearl 8100 is locked to another service provider. The only bypass for this would be to unlock your RIM Blackberry, or to subscribe to the service provider the phone is locked with.
Hi, go to your wireless provider web site and got their proper number "SMS Message Center Numbers".
On the phone, go to Options/SMS Text, move down to the Service Center line and put in the proper number remembering to put the + plus sign in front of it.
So if you get a Protocol Error and a Red X when trying to send SMS text, check this to fix it..
Hi, No sure to be honest.i did find a website i had unlocked mine. which might help you find the cheapest solution but not to be sure. Blackberry Pearl 8100 unlock code Hope this help.
Sounds like you have a broken trackball button membrane. The only way to get it up and running again is to open your
blackberry to physically clean or replace the membrane. If you want somebody else to do
it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how, the part is available on Ebay.
1.try to replace battery,if not 2.you may flash your BB using desktop manager 4.7 3.you can download firmware here:http://na.blackberry.com/eng/support/downloads/download_sites.jsp 4.usb driver must be install 5.heres the FAQ about blackberry,also a guide:http://forum.gsmhosting.com/vbb/showthread.php?t=560789 6.be patience while learning.
Did you turn your wifi?if not,turn it on then try again.Or you may try to restore/reset your BB.if it is still the same problem,you must upgrade the firmware.i,m pretty sure it will works fine.
i reset it already and upgraded the OS... its like the delete button is stuck and keep deleting stuff that i type...
